Sponsored by: Auxito
Transfer case shift relay compatibility
Old Sep 11, 2021 | 11:52 AM
Kyle Mendez's Avatar
Kyle Mendez
I have a 1999 f150 lariat with the 5.4 and auto transmission. The 4x4 works with the turn switch on the dashboard. 4x4 hasn't worked for a while and I suspect it is the transfer case shift relay. Took the relay out and brought it to the dealership, they say the part is obsolete and no longer offered through ford. Is this a part I could get out of a pick and pull or would that cause compatibility issues if it is not the exact same one? Is it similar enough to take from certain years or other trim levels? Would it just be easier to order one off a website, (any good ones?). Would appreciate any input.
Old Sep 11, 2021 | 03:21 PM
Stonedpony's Avatar
Stonedpony
You are talking about this relay behind the dash?
F85B-14B194-CA, 1998-2003 Ford F150 F250, 4x4, Transfer Case Relay Module
https://www.ebay.com/itm/252720761286
OR:
This one on the transfer case?
Dorman 600-802 Transfer Case Shift Motor for Select Ford / Lincoln Models
https://www.amazon.com/Dorman-600-802-Transfer-Case-Motor/dp/B000C0Y9E6
Rock Auto has both as well.
https://www.rockauto.com/en/catalog/...e+switch,13823
gale s
Oct 20, 2008 01:37 PM
lawnboy58
Bronco II
Sep 8, 2007 03:04 PM
lawnboy58
Bronco II
Sep 5, 2007 04:36 PM
good9682
Jun 13, 2004 11:03 PM
