Dim tail light... is it a bad ground?
Old Nov 2, 2003 | 09:36 AM
Big Red's Avatar
Big Red
The left rear tail light on my '83 F100 LWB is dim. I understand this can be caused by a bad ground. Where would I find the ground and how would I check it?
Old Nov 2, 2003 | 06:35 PM
35l911's Avatar
35l911
under the bed closest to the bumper check the trailer hook ups thats was my problem a faulty adapter
Old Nov 2, 2003 | 09:28 PM
83 F350's Avatar
83 F350
My 83 F-350 has all the wiring connections on the left side right in front of the rear bumper. A good place to start. If you can ran a jumper from a good ground to the ground on the light and that should tell you if you have a grounding problem.
Old Nov 4, 2003 | 08:01 PM
Big Red's Avatar
Big Red
Sometimes it is best to check the simple things first. I checked the bulb and it had turned a milky white instead of being transparent. I replaced the bulb and bingo... everything is fine now.
Old Nov 4, 2003 | 09:07 PM
plowpusher's Avatar
plowpusher
there is a ground wire right in side the tail opening in the bot chech it and clean the socket and the two metal stripps inside the socket change the bulb while ya got it apart
rworld
Apr 25, 2025 01:15 PM
steve2z
May 15, 2019 07:09 AM
72Blazerod
Mar 11, 2016 09:26 PM
96Pete379
Dec 9, 2015 08:53 PM
HoustonDave
Dec 1, 2015 10:06 AM
