2v to 3v
Old Sep 9, 2021 | 10:27 AM
Can't findmy10's Avatar
Can't findmy10
2v to 3v
Hello guys .I'm new to the forum .A lot of really good info here I see.
OK so I bought an 2007 E350 van .It's a 2V 6.8L engine.
​​​​​​ Engine is locked up and it seems that it was run low of oil. Friend has a 2008 f250 put a 3 valve engine in it. The f250 is wrecked but the engine is good ,it starts and runs -no leaks .
Question, if I am able to hold the imrc open will this engine run with the Van's pcm ? And /or
Does anyone know of any aftermarket intake for a 3V that has no IMRC ?
Old Sep 10, 2021 | 03:58 AM
JWA's Avatar
JWA
I believe this same question has been asked and answered in another sub-forum here? As already said you can NOT fit a 3v engine into an E-Series. Nothing else matters at that point.
Old Sep 11, 2021 | 11:17 AM
Can't findmy10
No ,it's In There .that is why I asked the question .Had to modify the exhaust to reach the manifolds used original oil cooler.pcv was tight but the engine is in .
I guess if It was a truck it would be the same question if going from 2V to 3V.
Old Sep 12, 2021 | 08:05 PM
maples01's Avatar
maples01
You are going to find out why Ford did Not put that in there.
Old Feb 7, 2024 | 09:46 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
I'm curious if this ended up working out or not.
Old Feb 8, 2024 | 04:48 AM
JWA's Avatar
JWA
^^^Its been over 2+ years since the OP has returned so chances are we'll never know how this did--or did not---work out.
1984nuckols
Dec 30, 2011 12:29 PM
deedzhq
Aug 4, 2011 12:10 PM
buyer
Dec 5, 2003 09:00 AM
JeffMasonCO
Aerostar
Jun 13, 2003 10:28 AM
