My 300 I6 ('84 Bronco) is making a chirping noise that follows the engine speed and appears when the engine is warmed up. The chirping happens w/o any belts attached, so I'm kind of lost as to the source. I saw mention of rockers, but I can't detect any of chirping noise coming from the oil file hole either. The chirping is much louder than in the video after its been driven for a while
If nothing pull the valve cover and look for obvious signs.
Thank you. Since posting that, I've narrowed it down to the balancer/front main area. The crank timing cover seal appears to be leaking a little bit of oil too. I'm working up to replacing the balancer and timing cover seal.
I'm 99% certain the timing cover crank seal was the problem. I've put about 50 miles on it, and the chirping noise is gone.
I replaced the timing cover seals and harmonic balancer. The previous harmonic balancer looked fine. The rubber was still pliable, and there was no obvious reason for it to be causing the chirping.
