Sponsored by: Real Truck
Output speed sensor Code 0720
Old Apr 25, 2026 | 08:30 PM
Fordman04's Avatar
Fordman04
4wd Low
Originally Posted by Mark Kovalsky
Having the P0720 codes does not mean you should change the output speed sensor. It means you should diagnose what's wrong. Most of the time the problem is in the wiring to the sensor, not the sensor itself.
Hi Mark, Thanks for responding. I see you have been a mechanic for a long time, can I ask you where in the wiring do problems usually occur? In the OSS wire connector itself or somewhere in the actual wires? Also do you think this wiring issue is causing the truck to stall in gear/idle and the occasional power loss and causing the 2 too lean codes P0171 & P0174? Thanks again... -Mike
Old Apr 26, 2026 | 08:50 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I've never worked as a mechanic.
As for specific spots where the wiring might fail, you probably should ask a mechanic with experience with that.
Old Apr 26, 2026 | 12:45 PM
Fordman04's Avatar
Fordman04
4wd Low
Oh ok, im sorry i thought it said you were a transmission mechanic.But Thank you I will ask my mechanic
SgtHch
Apr 7, 2015 10:41 AM
skyfox10
Modular V10 (6.8l)
Apr 14, 2014 08:06 PM
Methodical_1
Aug 15, 2010 05:42 PM
Explorer98
May 30, 2006 08:36 AM
