91 f150 has three codes
Old Sep 5, 2021 | 06:46 PM
rewiscody's Avatar
rewiscody
4.9/e4od
332 (egr is deleted)
452 speed sensor(replaced but still showing)
628 torque converter slippage. ( replaced months ago)
after sitting when you start it and put it into gear it feels like the transmission has to still build up pressure
it also runs rough when started after sitting but runs better after warm.
any advice
Old Sep 6, 2021 | 06:34 AM
My4Fordtrucks's Avatar
My4Fordtrucks
332 is insufficient flow. It can either be a stored code or show up in the KOER test. Which is it and how did you delete the EGR system? It still needs to be electronically connected to the solenoid or else it will set a code.
452 vehicle speed sensor signal fault. According to my book that will only show up as a stored code. Did you erase the codes after replacing the sensor?
628 excessive converter slippage. Is this a stored code or did you get it from the engine off test?
One possibility for delayed engagement is low fluid. Have you checked the transmission fluid level? It has to be checked at operating temp.
It’s hard to say what the cold start problem is without doing testing. It could be the temperature sensor providing a false engine temp.
Old Sep 6, 2021 | 07:49 AM
R&RFord's Avatar
R&RFord
How are you pulling codes?
Old Sep 6, 2021 | 09:14 AM
Conanski's Avatar
Conanski
Code 332: The same code # will mean different things for different years and vehicles. Insufficient flow only applies to vehicles with the DPFE egr system which is '96 only for these trucks. This '91 would have an EGR position sensor where the code definition is "valve did not open" when commanded, but with the EGR deleted there is no way to clear this code.
Code 452: This truck should not have the electronic speedo cluster... it should be mechanically driven via a cable from the trans or t-case. That is good news as there is no PSOM between the speed sensor and the PCM. But that also means the rear axle sensor does not serve as the VSS, the output on the trans or t-case should be a combo electrical/mechanical device such as this...
Code 628: Could just be leftover from the original problem, have you cleared codes to see what cones back? Stored codes do not self erase.
Old Sep 6, 2021 | 10:37 AM
My4Fordtrucks
The OP did not state which sensor was replaced when addressing the 452 code so…
Old Sep 6, 2021 | 12:24 PM
rewiscody's Avatar
rewiscody
I just put a plate between egr and intake and left plugged in,
I replaced the vss sensor in the picture and the abs sensor on rear axle.
how do I clear the stored codes
Old Sep 6, 2021 | 12:33 PM
Conanski's Avatar
Conanski
Is the vacuum line stil attached?
With a code reader or by disconnecting the battery for 5mins, but that also erases all adaptive learing the computer has built up for the engine and trans.
Old Sep 6, 2021 | 12:37 PM
rewiscody's Avatar
rewiscody
No I capped the vacuum line, should I plug it back in,
my Speedo is also worn out I think, reads30 at around 35, 35 at 45 and so on , could that affect vss code, I thought I didn’t have psom also
Geren8509
Mar 20, 2021 09:03 PM
cjennings5
Aug 9, 2014 05:30 PM
BearFootCustom
Jul 4, 2011 04:41 PM
GWTarpon
Feb 5, 2004 11:27 AM
