Trans Mount Bolt Broke ...
Old Sep 6, 2021 | 11:22 AM
89300T184X4's Avatar
89300T184X4
Happy Labor Day,
So I'm out here under the truck replacing motor mounts, and of course the last bolt gives me trouble. I ended up breaking this mount to trans bolt, Ford Screw 388824 in the diagram below.
Here's an image of mine now.
​​​​​​Someone in the past broke the other one off, because it was already drilled for a through bolt, and I'd like to do that now. Problem is I can't see how to get a drill bit to it without either removing the cross member or drilling an access hole thru the cross member. Can anyone say whether that is a good or terrible idea?
Worst case I'll bolt down the one side and limp it to a trans shop.
Thanks in advance.
Old Sep 6, 2021 | 11:50 AM
SFaulken's Avatar
SFaulken
The crossmember isn't that hard to pull out. The eight bolts on the bottom, and then just use a prybar and a deadblow hammer to knock it backwards a few inches.
Old Sep 6, 2021 | 01:10 PM
89300T184X4
Thanks the the tip, worked out just like you said.
Cracker289
North Carolina Chapter
39
Oct 5, 2021 01:32 PM
mr_ranger-79
Nov 8, 2011 09:55 PM
greaseball13
1983 - 2012 Ranger & B-Series
Jan 20, 2006 11:07 PM
junkyardjeff
Feb 17, 2005 07:47 PM
