Sponsored by: Real Truck
Brakes - Advise Please
Old Sep 5, 2021 | 01:22 PM
Ford20161965's Avatar
Ford20161965
2016 F350 WITH BRAKE BOOSTER ON IT. JUST STARTED DROPPING FLUID EVERYWHERE - PULLED THE INNER FENDER COVER OFF AND NOTICED OIL FLUID WAS COMING FROM A HOLE IN THE BOTTOM OF BOOSTER - SEEMS TO BE THREADED?! IS A BLEED BOLT MISSING? O-REILLYS HAS NO CLUE AND i'VE TRIED 6MM-7MM AND 1/4-20 AND NOTHING THREADS IN. NO BRAKE ISSUE IN 115K TILL NOW?? BLACK BODY CYLINDER BOLTED TO CAB WITH PLASTIC RESIVOIR SITTING ON TOP.
CAN SOMEONE TELL ME IF A BOLT SHOULD BE THERE AND WHAT SIZE IT IS BEFORE I HAVE HER TOWED TO A REPAIR SHOP?
Old Sep 5, 2021 | 01:41 PM
Rudiak's Avatar
Rudiak
Your brake booster is blown needs to be replaced.
Old Sep 5, 2021 | 02:45 PM
Ford20161965
THANK YOU VERY MUCH
Old Sep 6, 2021 | 08:04 PM
PJWhelan's Avatar
PJWhelan
Unlock the "Caps lock"......please.....
cowgirlup11
Nov 29, 2012 11:39 AM
meborder
Jul 16, 2012 10:27 PM
mddibenedetto
Apr 14, 2010 08:01 AM
Caleb H
48
Feb 9, 2009 05:02 PM
Crumm
Jan 12, 2004 08:11 AM
