How much taller are 2021 F350 blocks vs F250 blocks?
I wonder if the F-350 spring pack is slightly flatter(less arch) making it sit the same as a 250 when unladen.
I thought that was the case with the blocks. Does your brother's truck have any option packages that would effect the suspension, and is it the same year as yours? I ask because the standard F-250 spring pack is 3 spring.
Ok... talking about springs... can someone clarify how many springs these are... I know it sounds silly, but I am not really sure if the very bottom bar is counted as a spring. Also, is the F250 with HCTT not the same as a standard 350 spring wise?
So, here is a 2021 F250 Lariat with the HCTT package. Is this 3 springs and a helper, or 4 springs and a helper? Or is it just called 4 springs, or 5 springs?
And here is a 2022 F250 XLT without the HCTT package. Does this one have 2 or 3 springs?
The following users liked this post:
Thanks! This is what I thought... so my 250 with HCTT and snow plow/camper package will look just like the top pic, which is also the same set up as the (standard) 350.
ghunt
02-01-2008 10:48 PM
