Idle/miss issues
Old Aug 30, 2021 | 07:51 PM
pat_da_man's Avatar
pat_da_man
Idle/miss issues
Hi I’m having an odd issue with my 2001 f250 7.3 auto. I get an irregular idle (seems like it tries to stall then catches itself and bounces around)when it’s hot out or truck is really hot. Only notice it when I come to a stop or after sitting at a light for a few seconds.Have disconnected icp sensor and it goes away. Have just recently noticed that it happens when my son opens the rear door as if somehow related to dome lights or similar? (Drivers door sensor has been broken for years)Maybe related to brake lights? Is there a crossover between injection wiring and interior wiring? I have looked at the main harness from pcm and can’t find anything wrong. Any suggestions as to where to start looking would be greatly appreciated.
Thanks
patrick
Old Aug 31, 2021 | 06:15 AM
udsuth78's Avatar
udsuth78
The PCM does share a fuse w/ the aux power ports(cigarette lighter), not sure if other interior functions are on that circut though. Might replace the fuse and confirm the connection is tight.
Old Aug 31, 2021 | 03:17 PM
Brother Les's Avatar
Brother Les
Is there any oil at/in the ICP connection? If there is a oil leak at the connection, put a new ICP sensor on it.
Old Aug 31, 2021 | 08:28 PM
Jimmy's Pilot Service's Avatar
Veteran: Navy
Last year I had a slight surge in my idle after several outings with the truck at normal temps. Turns out the ICP as going bad, had oil weeping out of the top. Changed it and runs good again. Remember it is an O ring connection and snug is good. Maybe 15 or so foot pounds is plenty.
Also check the plug and pig tails for age signs.
Old Aug 31, 2021 | 11:56 PM
pat_da_man's Avatar
pat_da_man
Replaced icp ~4 months ago with a Ford one also replaced pigtail am going to look into fuse block
wondering if it’s a pcm issue?
Old Sep 1, 2021 | 12:59 AM
Veteran: Navy
Have you used a good scanner (not auto part store type) and pull the codes? FORScan is a good choice. If you have not pulled codes and made sure they are current and relevant you will just be throwing parts at the truck..
1977scoutii
Jul 10, 2021 09:16 PM
2006powerstroke90
Apr 4, 2021 06:01 PM
gpeade
Sep 18, 2020 11:27 AM
johnnyjewell
1997 - 2003 F150
Sep 7, 2003 08:05 PM
nismo_2
1978 - 1996 Big Bronco
Feb 4, 2003 08:19 AM
