another EGR question
Old Aug 30, 2021 | 02:00 PM
fiend$$138's Avatar
fiend$$138
4wd Low
Hi. Lost my original FTE account info (hadn't been on in a few years), but I'm back again. I just inherited my grandfather's 1973 F100 XLT Explorer, 390, A/T. It is all stock best I can tell and in great shape and runs really well other than being hard to start after engine is warmed up. Usually have to push pedal to the floor while cranking.
While replacing the fuel filter that connects directly to carb, the filter stripped right off and left the threaded piece in the carb. I could not get it out; even tried an EZ out.
Anyway, decided to replace carb. After pulling it off, I noticed that the aluminum carb spacer/EGR plate was burned up/melted a bit as seems to be common.
The EGR valve did not have a vacuum line connected to it.
If I completely remove/delete, the EGR and install a carb spacer without the EGR hole, what other adjustments will need to be made?
I came across threads that mention possibly replacing jets and recurving the distributor, but they didn't mention specifics...like what size jets, what to set distributor to.
Any help is appreciated.
Old Aug 31, 2021 | 06:03 AM
fiend$$138's Avatar
fiend$$138
4wd Low
The day I got her home to Maine-drove her all the way from Georgia.
Old Aug 31, 2021 | 07:01 AM
somethingclever's Avatar
somethingclever
Great truck!
In the past I found a phenolic 2bbl spacer to replace the EGR plate on the factory intake and it worked great.
To select the right fuel jets, you will need to purchase and install a wideband AFR gauge to know where you need to be.
77Jade
13
Jul 31, 2018 10:41 AM
TERZI
Oct 10, 2011 07:36 PM
TrainPRes
Sep 12, 2011 06:08 AM
sharpassrazor
Feb 26, 2004 02:04 AM
bigwalt1
Nov 7, 2003 09:16 AM
