2010 flex
Old Aug 30, 2021 | 11:59 AM
wilh's Avatar
wilh
2010 flex
i need some help , does the 2010 flex with factory 7 wire trailer harness have a battery charge trailer tow relay? i sure can't find one, also iam getting no power to my plug for lights, on the 7 wire or the 4 wire, vehicle lights work but not the trailer lights
Old Aug 31, 2021 | 06:50 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
Check your owners manual for the location it should be in. Usually under the hood in that fuse panel. If not there, buy one and stick it in there. If you didn't buy it new, previous may have pulled it or Ford never out it in. If you don't have the manual, go to ford dot com and download it.
Old Aug 31, 2021 | 02:37 PM
wilh's Avatar
wilh
for anyone else having this problem with their 2010 flex, no trailer lights. to make it ez for you fuse F2 15 amp on the secondary fuse box under the dash, that it, change it and you should be back in business
darylksu
Apr 12, 2019 11:59 PM
warneroutdoor
Jan 19, 2015 01:40 PM
SD Dually
Feb 19, 2014 10:41 PM
thedaddycat
Dec 27, 2006 06:08 AM
solomon
1997 - 2003 F150
Dec 16, 2005 03:30 AM
