Sponsored by: Auxito
trailer lights always on
Old Dec 14, 2005 | 06:37 PM
solomon's Avatar
solomon
for some reason, when I hook a trailer up on my truck (97 f150), the running lights on the trailer are always on, even when the truck lights are off. Regular 4 prong plug. Any ideas?
Old Dec 14, 2005 | 07:05 PM
alchymist's Avatar
alchymist
"Mifflin Clay"
Sounds like you got a wire shorted to 12 v somewhere. Take a test light and check each pin on the truck end of the plug to see if there is 12 volts on one pin with everything turned off. If one pin has 12 volts, follow it --
You didn't say if the trailer has a battery installed for any reason .......
Old Dec 14, 2005 | 08:21 PM
solomon's Avatar
solomon
no battery on the trailer, and yes the pin with the brown wire (1st in from the ground) is hot with everythig turned off.
Old Dec 14, 2005 | 08:33 PM
steve(ill)'s Avatar
steve(ill)
the brown wire is the tail light wire and is not only when the lights are on. under the truck by the spare tire there is a plug and bunch of wires. the RED wire is always hot. somehow you got the brown trailer plug wire connected to the RED 12 volt wire, not the tail light wire.
Old Dec 15, 2005 | 09:22 AM
projectSHO89's Avatar
projectSHO89
A shorted Trailer Tow Running Lamp relay will cause this. Pull the relay to see if the always-hot wire goes away.
Steve
Old Dec 15, 2005 | 06:48 PM
solomon's Avatar
solomon
do you know where I can get a relay/fuse diagram for that truck. I bought an aftermarket manual and it dosen't have one. Don't have the original book.
Old Dec 16, 2005 | 03:30 AM
Bargod's Avatar
Bargod
In the block under the hood, I think it's the first or second one from the driver's side.
KCBS Smoker
Apr 29, 2024 10:59 AM
351Cleveland C4
Jan 20, 2014 07:49 PM
irydhd
2009 - 2014 F150
Mar 19, 2012 02:05 PM
MDSuperDuty
Apr 27, 2011 06:23 PM
Zirk
1983 - 2012 Ranger & B-Series
Jan 21, 2009 10:19 PM
