My project ruck '04 f350 6.0 still has no code problems.
Truck starts and idles fine but 1000 rpms is all I can get.
Started out having tranny problems not moving when in gear. No codes with my AE. Changed all the sensors inside tranny. Now I have forward gears but no reverse, when put in reverse it eases forward. Still no rpms.
Only codes showing is P1876 transfer case 2-wheel drive solenoid circuit failure
P1832 transfer case differential lock-up solenoid circuit failure.
P1865 Transfer case contact plate power short to ground.
I know I should not change parts without a code but, when there are no codes I have to try something.
