DRW to SRW Conversion
This may be a topic that has been covered but I can only find a couple of threads that barely touch on it...
In my what seems like eternal search for a 2WD SRW Crew Cab, all I'm really finding are ones that will require a lot of work to resurrect or duallies. What is involved in changing the setup from DRW to SRW, doing it correctly, without cobbing anything together.
My main questions are:
-What's behind the rear "fenders"? Are they just attached with screws or rivets, so only holes, or is part of the bed actually cut out behind them? If that's the case, is my only option a donor bed, and will the bed from an F-250 work? This also raises a question about filler necks...
-What rear axles can I use that will bolt right in with minimal modifications, and what would those modifications be?
-What must be done to the front end, if anything?
If it's important to take into consideration, I'd want to end up with something like the American Racing Outlaw wheels all around.
Thanks for any input!!
A SRW axle will bolt in onto those leaf springs and let you run SRW wheels. On the front you need to get the SRW front hubs and rotors and of course the wheels. That's it. Your best option would be to get another SRW truck, something more common and easier to find. You could then get the complete bed and rear axle from it, and also the front brake pieces you need to change it to SRW.
Stupid question, but are all the beds across the spectrum for 80-86 virtually the same? So if I ended up with a parts truck F-250, I could use the axle, bed and front hubs on the DRW truck?
Any one style axle I should be looking for? I'm thinking a 3:55 is my best bet for all around driving...
I am assuming so long as both the DRW and SRW trucks are Cab/Pickup trucks, this would hold true.
Quick question about this, does this mean if i have an f150 SRW and found a DRW f350 that I want the engine, trans, and frame for, it's just swapping my front hubs and rear axel then bed and cab? The 350 is missing the bed and cab is shot with no title. Would this then give me the 350 gvwr or since it has 150 parts it would be the 150's? Thanks!
You may have a problem with the title. It's illegal to swap vin tags. The VIN has a number or letter in it that designates if it's a f150 or a f250 or a f350.
I read it several times and not sure exactly what you want to do, but the f150 axles are different. The bearings are smaller, they only have 5 lugs versus the 8 lug f250/350. While the f150 rear axle will bolt in, you would only have f150 capacity. Not sure about the front axle. but if it did fit, you would be only f150 capacity, same as the rear, smaller bearings, 5 lug rims. The body parts will swap. The engine/trans will swap with the correct motor/frame brackets.
I have title for my f150 cab, I always thought the vin went with the cab right? Not the frame?
yea so the f350 has no title or bed and the cab is shot. My f150 has rust, but has title and bed. I wanted to know if I could put the cab, bed, and rear axle in the f350. Both are 2wd to make it a srw f350. Is the axel a limiting point? I always thought it was more frame strength and suspension. Aside matching the lug pattern, I can't imagine I'd have ti swap the front hubs right? As far as the engine and trans, it's the same engine and I plan on using the f350 trans
As for the 150 axle bolting to the 350 springs I am not sure but think it may BUT .........
The wheel bolt pattern of the now 150 rear axle will not fit the front 350 hubs.
Then you said something about GVWR.
If you do the 150 cab / bed swap on to the 350 frame / running gear the truck should have the GVWR of the 350 BUT ......
if you are pulled over for a weight issue and they check the door sticker it will have the GVWR of the 150 and that is what they go by.
They dont care the 150 body is sitting on a 350 frame / running gear the sticker said 150 GVWR and you get a ticket and not a good one
In the end why the 150 rear axle with the cab / bed in to the 350 frame?
What is it you are looking for as an out come?
The higher GVWR of the 350? If so you cant use the 150 axle in the 350 frame and have the 350 GVWR as the 150 axle cant handle it.
BTW if you do the 150 cab / bed swap on to the 350 note if you go to sell and someone looks at the VIN's they will not match the body & frame.
What might help is if you can get a BOS for the 350 even with out a title you have proof you bought the 350 and did not steal it when sh** hits the fan.
Just my .02
Dave ----
The cab & bed will fit the 350 frame if it is a pickup frame and not a CC frame.
Just my .02
Dave ----
Just my .02
Dave ----
Your path on this one if you wanted to pursue it, would be to complete your plan, use the f150 cab and title, axles, etc., and have a f150. It will look like a f150, and have the capacity of a f150 and the title would say it's a f150. It would just have a f350 frame which no one would be able to really tell, it's just a little bit thicker. No f250/350 duties, though everyone overloads their f150 anyway.
