blowing fuses in #22 glowplug controller
Old Nov 1, 2003 | 06:07 PM
kentb's Avatar
kentb
Unhappy blowing fuses in #22 glowplug controller
please help.I was driving down the road a 1/4 mile from house and 1997 ford power stroke died.I checked fuse
#22 30 amp and it was blowen.I replaced it with another
and it blew too.I call dealer and they said it was a glow
plug relay.I replaced that ,but it still is shorting out the
fuse in #22 which handles the the glow plug controller.
lights and everthing else works but the wait to start light
I wandering where the dead short is causing this problem
thanks for any help
Old Nov 1, 2003 | 06:35 PM
lymant's Avatar
lymant
kentb:
On the drivers side of the fuel filter housing you will find a wire that slips on to a tap. This tab is connected to an electrical component that is mounted inside the fuel filter housing which is about the size of a nickel. You can safely remove the wire and then see if your engine starts if it does change this component. Also the shaft inside the housing may have left hand threads remove this so you can also check the heating element that lays in the bottom of the fuel filter housing.
Old Nov 2, 2003 | 05:43 PM
lymant's Avatar
lymant
KENTB:
I'M INTERESTED TO KNOW THE OUTCOME ON YOUR PROBLEM. PLEASE KEEP US INFORMED.
THANK YOU!
Old Nov 3, 2003 | 10:19 PM
kentb's Avatar
kentb
Talking
Yes I tired what you said it was the heater element that
was bad.I the truck started right up.I really appriecate your kindnessI went day to get the heater parts from the dealer andtry to put them in You a kind and classy guy to help me bless you kent
Old Mar 10, 2007 | 08:01 AM
96fordf2507.3's Avatar
96fordf2507.3
i have the same problem with my 1996 ford f250 7.3 but i did that tap thing and it didnt start so what is the problem now?
thanks
jourdan
Old Mar 10, 2007 | 08:25 AM
Cuda_jim's Avatar
Cuda_jim
thanks
jourdan
Did you notice this is a 4 year old post?
If you are blowing #22 fuse, disconnect the wire on the filter housing.
THEN replace the fuse with a good one.
REad these:
https://www.ford-trucks.com/forums/5...superchip.html
https://www.ford-trucks.com/forums/5...fuse-22-a.html
If this doesn't help, Start another thread asking your specific question. Post it in the forum for your year truck.
Post it Here:
https://www.ford-trucks.com/forums/f...play.php?f=170
Old Mar 10, 2007 | 11:29 AM
96fordf2507.3
where is the filer housing. ive goen threw lie k5 fuses today trying to start her up and still no luck. it only does it when its cold out and if its not pluged in for a lil while to.and i replaced the gloe plug realy to.so what shoudl i do know?
Old Mar 10, 2007 | 11:53 AM
Uzumati's Avatar
Uzumati
96 you need to post this question here https://www.ford-trucks.com/forums/forum170/ our trucks are just a little bit different than yours but enuff so for us to throw you off in fixing it.
Old Mar 10, 2007 | 12:48 PM
Cuda_jim's Avatar
Cuda_jim
You need to read the links I gave you in my previous post. All you answers are in them.
Also, you are asking questions in the wrong forum. The guys here are very knowlegable and will help you but you will get more responses to your questions in the correct forum.
