Front Brakes Dragging
Old Aug 25, 2021 | 06:56 PM
thefoundingfather's Avatar
thefoundingfather
Recently replaced just about everything in the brake system, minus hard lines, rabs and booster. After replacing, my front brakes are dragging and I can’t seem to figure out why. I’ve bled the system more than I care to admit. Any help would be greatly appreciated.
Old Aug 25, 2021 | 08:27 PM
mechmagcn's Avatar
mechmagcn
If you replaced the master, check the rod from the booster adjustment. Sounds like your master isn't fully retracting.
Old Aug 25, 2021 | 09:50 PM
thefoundingfather
Even after I adjusted the push rod they still drag. I almost have to adjust it the point that I have no brakes.
Old Aug 26, 2021 | 08:24 AM
mechmagcn's Avatar
mechmagcn
Going by your original post, you replaced the calipers and pads? Front brake hoses?
If you crack a bleeder, do the brakes release?
brc777
1997 - 2003 F150
Apr 26, 2021 10:01 PM
jdmc148
Aug 15, 2014 12:50 PM
f100help
Sep 2, 2010 08:39 AM
F-150_XL
May 12, 2005 07:18 AM
seans64'
Oct 23, 2003 12:40 AM
