No charge
Old Aug 26, 2021 | 01:19 PM
Eric Hamilton's Avatar
Eric Hamilton
Check out the PDF instructions for the 3G Upgrade. Maybe this could be used towards the GM 3 Wire.
File Type: pdf
File Type: pdf
Old Aug 26, 2021 | 02:34 PM
Matts72's Avatar
Matts72
Eric, that helps. I may just go back to my conversion idea and use the green/red wire as the switched source. I already modified the 10SI case and original bracket. I don't need all the amperage of the 3G Ford alternator and the GM one is only about 20 amps more than my original alternator.
I did a bit more researching and there are true 1 wire GM conversion alternators available that have a self exciting regulator.
Old Aug 26, 2021 | 10:42 PM
ford390gashog's Avatar
ford390gashog
Originally Posted by Matts72
Yellow wire is 12V, Grn/red is .049, orange is 0
So you found your issue. Now trace the green/red back to the cab and figure out where the connection is broken. Most of the time it's from a bad ignition switch.
Old Aug 27, 2021 | 01:11 AM
Matts72's Avatar
Matts72
390-
So is the problem in the lock cylinder part, mine is pretty loose, or in the wiring part in the back?
Old Aug 27, 2021 | 07:11 AM
Eric Hamilton
Matts72, once you correct and get 12 volts to the red/green wire, you're on you way. See the below pictures of my 71' F250 wiring with the 3G. Note the yellow wire is a simple direct to battery connection. I used the battery terminal clamps with multiple ports to keep everything separated and in plain view. Wire loom is on order to dress everything up in the near future.
Note the yellow wire coming off of the alternator directly to the battery.
Red/Green wire goes to new all green wire of the harness. This is the 12 volt ignition source.
Unplugged the plug off of the horn relay/field relay. Cut the 2 wires with the green tape to keep 12v from going to the ammeter gauge in the truck. Will convert to volts from amps down the road.
Old Aug 27, 2021 | 10:29 PM
Matts72's Avatar
Matts72
Eric, I believe that would be identical to how the GM 10SI 3 wire alternator would setup as well.
In my case I need to figure out the red/green wire situation first. That should allow me to continue using the factory alternator.
Old Aug 28, 2021 | 05:14 PM
Matts72's Avatar
Matts72
When all else fails, check for broken wires for the 37th time. Grn/red wire was hacked into by previous owner (my dad) and the connection came loose. It's charging now!
Old Aug 30, 2021 | 07:02 AM
Eric Hamilton
Great news Matt!
Weeks77
Large Truck
Dec 3, 2024 09:50 AM
seagiant
27
Aug 20, 2021 01:35 AM
Virginia Squire
Aug 12, 2010 09:22 AM
eicht
Nov 27, 2009 10:48 PM
whitesdford
Dec 12, 2007 08:29 PM
