Engine lift tool for manifold replacement.
Old Aug 24, 2021 | 03:19 PM
ahmad_f150's Avatar
ahmad_f150
Hello,
I am thinking about changing exhaust manifold on f150 2007..4.6, I think for to remove passenger side manifold you have to lift engine few inches.
I saw some videos where they have on big bar sitting on side walls of the hood area, and one big nut/bolt lift engine up when you circle the nut.
I don't know what it is called and who sells it.
Thank you
Old Aug 27, 2021 | 06:19 PM
guyina4x4's Avatar
guyina4x4
Bottle jack
When i did mine i used a jack from below with a piece of 2x6.
i don't think it helped much.
The front 2 bolts are near impossible to access either way.
Old Aug 27, 2021 | 07:34 PM
ahmad_f150's Avatar
ahmad_f150
Were you able to slide manifold out because you lift the engine.?
I guess 2x6 with jack is some what safe, as it wont break any part of the engine.
Old Aug 28, 2021 | 07:33 PM
redfishtd's Avatar
redfishtd
Are you considering an hydraulic engine lift .
Old Aug 28, 2021 | 08:15 PM
ahmad_f150's Avatar
ahmad_f150
Not at this point. I am new to fixing things so do not want tools which seasoned professionals use.
when time comes I am going to try 2x6 + jack idea first.
But I will think about it where I could store it in the garage..
john-9
Apr 18, 2021 08:49 AM
MannyC750
15
May 25, 2020 12:13 PM
2fifty
Sep 28, 2017 07:20 PM
Jsek
Jan 23, 2017 08:27 PM
Camperdaddy
Exhaust Systems
Jun 3, 2007 07:18 PM
