Sponsored by: Real Truck
Bearing noise?
Old Aug 24, 2021 | 02:21 PM
mongobuddy's Avatar
mongobuddy
Bearing noise?
1999 F250 SD 4WD, ESOF, i hear a noise similar to rumble strips intermittently. sounds like the LH front, will go away if hubs are locked. Buddy seems to think wheel bearings. Anyone had anything like this? thanks
Old Aug 24, 2021 | 02:27 PM
WWR's Avatar
WWR
Wheel bearings are unaffected by locking the hubs.
Could be the bearing that supports the stub shaft.
Could be vacuum hubs partially engaged, if so equipped.
Old Aug 24, 2021 | 03:28 PM
nydiver's Avatar
nydiver
You mean stuck, half in half out and the splines are just grinding away on the extremes. Might be time to disassemble, clean, and grease pack your hubs, maybe replace the one. Every year you should take the hubs apart and lube em up so they work 100% of the time and never bind. 30 minutes of work to ensure they're always there when you need em.
Old Aug 25, 2021 | 07:03 PM
mongobuddy's Avatar
mongobuddy
Isnt the stub shaft bearing in the hub assy? it shouldnt be rotating in 2HI right? Unlikely hubs are stuck, had no vacuum lines connected at the time
Grease & Gravel
1983 - 2012 Ranger & B-Series
Mar 24, 2017 09:42 PM
CobraGT40
Sep 21, 2012 12:26 PM
paul.meredith
Mar 4, 2011 09:42 AM
bonsiguy
Jun 21, 2007 09:19 PM
timmyp
Dec 12, 2005 07:55 PM
