So I was under the impression that the primary cooling system on the 6.7 diesel was for the engine and the secondary was for the transmission. Then a read the following statement on the SPE Thermostat page....
"2017+ Powerstrokes use the primary cooling system to cool the transmission unlike the 2011-2016 which uses the secondary cooling system."
So if this is true, what is the secondary cooling system used for?
