Backup Light Connection Issue - Need Advice
Old Aug 23, 2021 | 10:07 AM
dmassey321's Avatar
dmassey321
Trailering
Hello All,
This weekend, I installed an LED light strip just above the bumper (below the tailgate). It came with a harness with a 4 pin connection to plug into the trailer 4-pin. This worked great and covered every function (left, right, brake, hazard) with exception for the backup light circuit. By reading other posts, I connected the backup wire for the LED strip to the backup wire from the rear side of the 7-pin connection (center wire) utilizing a T-splice connector. Everything works as it should. However, on the way into work today, I kept getting “Trailer Connected” and “Trailer Disconnected” warning messages. I could not seem to replicated it in a way that I can pinpoint when or what drives the message (i.e. every time I used a turn indicator or every time I hit the brakes). The 4 pin connector is solidly in place and has dielectric grease appropriately applied. I did not employ any type of relay with the install.
Any thoughts would be most appreciated.
Old Aug 23, 2021 | 10:15 AM
B-ManFX4's Avatar
B-ManFX4
I ran my LED backup lights on my F-150 exactly like you describe for 4 years with no issues at all. On my Super Duty I used a relay tied to the lighting circuit so they only illuminate if the lights are on too. As far as I can see I do not see detection circuitry on the reverse wire circuit. I would double check your big connectors going to the hitch, etc. under the truck.
Old Aug 24, 2021 | 10:05 PM
tdbohannon's Avatar
tdbohannon
May or may not be related, but I had an issue w the trailer connected / disconnected happening and it was due to a grounding issue w my trailer brake wires. Maybe there’s a ground issue w the light bar?
Old Aug 25, 2021 | 08:35 AM
mewaschuk's Avatar
mewaschuk
you cannot use the 4 pin on the bumper. there is a splitter pigtail that goes in the wire harness above the spare tire. some also have an extra 1 wire lead for the reverse light so no splicing needed. had to do the same thing on my sled deck.
Old Sep 8, 2021 | 09:05 AM
dmassey321's Avatar
dmassey321
Trailering
https://youtu.be/YreVxl-FLoM
I purchased the pigtail/splitter and re-installed. Still have the same issue…getting “trailer disconnected”, “trailer turn signal fault” types of messages. As an aside, prior to ever installing, I would occasionally get these messages when towing the airstream…got di-electric grease as a possible solution but no bueno. It did not happen as frequently as it does now. Now, every time I put the brakes or turn indicators on, I get a message. About ready to rip it out and throw it in the trash.
Old Sep 8, 2021 | 09:40 AM
grumblin's Avatar
grumblin
I'm betting this has nothing to do with your light bar. Since you had a pre-existing electrical gremlin, it's being exascerbated by the light bar installation. Going to have to go find the underlying issue.
Rule #1: Fix any "weirdness" prior to adding aftermarket items.
Rule #2: See rule #1.
GMoney1121
Nov 23, 2024 07:20 PM
1978f-250
25
Jul 5, 2017 12:13 PM
ihbond
Dec 28, 2013 11:33 PM
EconolineFan
Apr 16, 2011 09:56 PM
wgouldin
Sep 4, 2007 04:34 PM
