Need help identifying a noise from the rear end of my 2018 F250 xlt gas with about 55k miles. I will hopefully be able to attach a link to a video but basically I have a rotational squeak from the rear. I hear it low speeds and primarily only during slight acceleration. Does not seem to be associated with braking. Any help would be appreciated. Thanks
Have a similar noise going over bumps and finally found it to be the little pad between the leaf springs. Worth a look, will take mine to the dealer to fix under warranty some time. Spring insulator.
i didnt know leaf spring squeek is covered by warranty. at any rate theyll probly just spray wd40 on there. if they do anything at all.
you must have alot of free time to visit a dealer for every little squeek
On my 2011 I had a similar problem. Turned out to be the internal parking parts falling apart. Not all the time and sometime very loud, sometimes barely audible.
I was having a noticeable squeal/whistle/chirping sound coming from the middle of my truck between 5-10 mph. I narrowed down the location after rolling downhill in neutral with engine off and the sound was not affected by applying the brakes. I had the Transfer Case Output Shaft Seal replaced...fixed the issue...
