00 rear end
Old Mar 21, 2006 | 07:28 PM
iam2jimbo's Avatar
iam2jimbo
Unhappy 00 rear end
Im looking into rebuilding the rear end. Drove home from KC KC.and it sounded like my rear end was going to fall out everytime i hit a bump. chatering clatering and poping.
Old Mar 22, 2006 | 09:53 AM
l-m tech's Avatar
l-m tech
check the rear sway bar links.they are known to go bad and make a rattling noise when hitting bumps.
Old Mar 23, 2006 | 09:14 PM
iam2jimbo's Avatar
iam2jimbo
I jacked up the driver side and turned the axle. It didnt sound good at all.
I know that its the rear end but dont know how bad.
Planed on working on it this weekend, but going to TX insted.
I haul new cars for a living. got to make that money to put into the rear end.
I am confedent that I can do the job, was hoping for some insight.
Old Mar 24, 2006 | 09:38 PM
iam2jimbo's Avatar
iam2jimbo
come on guys help me out here
Old Mar 24, 2006 | 10:36 PM
MisterCMK's Avatar
MisterCMK
I will reply in the morning
Old Mar 25, 2006 | 07:53 AM
iam2jimbo's Avatar
iam2jimbo
Thanks in advance
Old Mar 25, 2006 | 08:45 AM
JayS's Avatar
JayS
I'm interested in this too. I know the clutch packs are shot in mine and I'm debating doing it myself or taking it to the shop. My summer toy is back on the road now so I can afford to have the truck down for a few days if need be.
Old Mar 25, 2006 | 04:30 PM
MisterCMK's Avatar
MisterCMK
I felt like crap last night, so I had to postpone my reply until today.
As for your rearend problems. Rebuilding the rear end isn't that difficult but it is a time consuming job. As long as you don't have to remove the gears it won't be bad. It sounds like your trac-lok is going out. What I would do is jack the truck up and pull the diff cover. When you pull the cover off you can examin the gears and make sure that they look fine. You can get a rebuild kit for the limited slip from Ford.
I would also check all the bushings in the rear end while you have the truck in the air.
Old Mar 26, 2006 | 01:46 AM
iam2jimbo's Avatar
iam2jimbo
Thanks for the info, can't wait to get back home and tear into it. wont be in town till thur or fri.
