1978 - 1996 Big Bronco
replacing distributor
Old Nov 1, 2003 | 02:18 PM
NJbronco138's Avatar
NJbronco138
I want to replace my distributor. I have read the haynes manual and it seems simple enough. I have a question though. It says you have to set the motor to TDC. Can I avoid that? I just want to see if i can simplify this a little more.
Old Nov 1, 2003 | 02:48 PM
jimzdat's Avatar
jimzdat
They recommend putting the engine at TDC just for ease of the job--if you walk away, or make a parts run, you know it'll be at TDC when you come back (in theory)
As long as you mark the position of the rotor before removing the old one (make sure you mark it on something other thatn the distributor cap adapter--you laugh, but I've seen people do it) then you can just pull and replace the distributor no problem.
Chances are, you won't get the thing put back in exactly in the right position, so you'll have to reset the timing, but that's easy enough to do
Old Nov 1, 2003 | 03:47 PM
NJbronco138
thanks, what do you recommend i mark the rotor against?
Old Nov 1, 2003 | 06:40 PM
jimzdat's Avatar
jimzdat
When I changed mine out (couple weeks ago on the side of the road--not a good weekend) (I also have a 91-Eddie Bauer BTW)
I just popped the cap off, and it happened to be pointed at the #5 Fuel injector--gave me a good reference point
All you need is some sort of mark to point it back in the same direction--if it's a tooth off, it'll be fairly obvious
fordf348
Apr 2, 2014 11:53 AM
yankeerebel
Oct 27, 2011 07:49 PM
Ratt617
Nov 11, 2010 09:01 AM
darrin1999
Mar 1, 2008 10:59 PM
