Can't get timing right
Old Aug 21, 2021 | 11:23 AM
RickyBerd's Avatar
RickyBerd
So im trying to advance the timing on my '92 f250 460 to around 12-13. Ive followed all the instructions i can find on here.
1. Warm up engine
2. Check timing
3. Turn off engine and unplug spout connector and loosen distributor clamp
4. Restart engine and check timing/adjust to 12° mark
5. Turn off engine, tighten clamp
6. Start engine and check that dist didnt move when tightening
7. Turn off engine, reconnect spout connector
After reconnecting the spout connector I see that the timing has advanced another ~5 degrees and I get pinging uphill under moderate acceleration.
Should I set timing to ~7° so that when I plug the spout connector back in it'll be at 12ish?
Old Aug 21, 2021 | 12:20 PM
sandymane's Avatar
sandymane
With the spout disconnected you are setting THE BASE TIMING. When the spout is reconnected, the PCM has control of timing based on preset parameters. Try setting base timing to 10 degrees and check your results.
Old Aug 21, 2021 | 01:18 PM
Conanski's Avatar
Conanski
You can safely skip all the starting and stoping of the engine, worst that will happen is a code gets set. Factory base timing setting is 10deg BTDC, some motors can handle more.. some can't.
Old Aug 21, 2021 | 03:19 PM
RickyBerd's Avatar
RickyBerd
Thanks guys. Turns out I'm an idiot and mis-marked my chalk lines. Actually had it set closer to 15° at first. Kicked it back to 12° and its fine now
Old Aug 21, 2021 | 03:34 PM
sandymane's Avatar
sandymane
Glad you got it and thanks for letting us know. Sandy
brendo613
Dec 28, 2011 04:25 PM
GIXXED
1978 - 1996 Big Bronco
Jan 1, 2008 01:46 PM
buffalobob
Dec 24, 2007 05:31 PM
cfhurdle
Dec 2, 2004 05:07 PM
xtmanx
Sep 30, 2004 12:09 PM
