Sponsored by: Real Truck
AC experts?
Old Aug 21, 2021 | 11:02 AM
jav_eee's Avatar
jav_eee
AC experts?
Long story short I've been fighting with 60 degree vent temps at idle. System has been charged properly, I cleaned the condenser, and just the other night cleaned out the evaporator. It was covered in crap. After reinstalling everything I turned it on to test the system. At idle, in 82 degree ambient, the vent temp got all the way down to 46 degrees. So I got out of the truck, leaving it on, to put some tools away. A couple of minutes later I got back in to check temps and it was 55 and climbing. Last night, same 82 ambient, I could not get it lower than 60 at idle again.
Anyone know what might have happened? Why was it able to get down to 46 (and dropping still) but then go back over 50 to never see the 40s again? All running conditions were the same. Which doesn't matter because the night it saw the 40s I hadn't done anything to affect the system other than allow it to continue to idle? I'm stumped.
Old Aug 21, 2021 | 11:39 AM
alloro's Avatar
alloro
What vehicle?
For your issue my first thought is the condenser fan isn't coming on or if it is it is not spinning fast enough to draw sufficient air through the condenser. If it cools good while driving over 35 MPH then the fan is the likely culprit.
Old Aug 21, 2021 | 12:24 PM
jav_eee's Avatar
jav_eee
Originally Posted by alloro
What vehicle?
sorry it’s a 2004 6.0.
Well the interesting part is the first night when I saw the 46 at idle, the truck wasn’t warmed up yet so the fan wasn’t on. But last night, same ambient temps, the truck was warmed up and the fan was turning faster. But it wouldn’t get colder than 60 degrees at the vent.
Old Aug 21, 2021 | 09:06 PM
Fefanatic's Avatar
Fefanatic
Was that 60 degree temp with max ac or normal? What was the temp in the cab at that time? How was the humidity?
Old Aug 22, 2021 | 12:53 PM
AK4x4's Avatar
AK4x4
First thing, make sure everything, radiator, condenser, and inner cooler are clean, then get out on the highway. If the AC works normally at highway speed, then you have a cooling fan issue. If the highway test indicated a cooling fan issue, then you probably need a new fan clutch. The exception is if your EGR valve has been deleted. A missing EGR valve screws up correct cooling fan function. So if the EGR valve has been removed, get one and plug it back in. Good luck, Russ
Old Aug 23, 2021 | 12:42 AM
2004 F450's Avatar
2004 F450
Check if you heater supply valve is open.
Old Aug 23, 2021 | 07:51 AM
jav_eee's Avatar
jav_eee
cleaned all that out. Cools down to the 40s while moving. It’s definitely the inadequate cooling provided by the stock electronic clutch fan. My EGR is in place and plugged in.
at idle, the cooling fan spins at around 850 rpm. I guess that’s just not enough.
Old Aug 23, 2021 | 07:52 AM
jav_eee's Avatar
jav_eee
I have verified it functions properly.
Old Aug 23, 2021 | 08:14 AM
projectSHO89's Avatar
projectSHO89
If you want maximum air conditioning cooling, the valve must be CLOSED in MAX A/C position.
Prep the truck for testing by following the prescribed steps in the service manual, connect your gauge set, and perform proper diagnostics instead of guessing.
Vent outlet temps are good for telling you when the system is working well or not but they cannot provide insight into what the system is doing (or not) and why.
Record and report the readings along with the ambient testing conditions for analysis assistance, if needed.
Old Aug 23, 2021 | 02:28 PM
jav_eee's Avatar
jav_eee
that heater valve is closed while on Max AC.
I wish I had a service manual. Need to look for one (even if I have to pay) again.
last readings at 92 ambient were 37/260 if I remember correctly
Old Aug 23, 2021 | 06:04 PM
Fefanatic's Avatar
Fefanatic
What it the temperature entering the evaporator vs exiting the evap? You pressure readings aren't indicative of a fan issue if those are correct. It could be just a tad low on Freon
Old Aug 23, 2021 | 06:08 PM
jav_eee's Avatar
jav_eee
how do I check that?
also, I find that with a couple of ounces more it puts out “warmer” air at the vent. Only a couple of degrees but still warmer. So I decided to leave the refrigerant charge where it’s at.
Old Aug 23, 2021 | 06:21 PM
Fefanatic's Avatar
Fefanatic
I get these problems in the shop quite a bit. Since you don't know the volume of refrigerant in the system it needs to be recycled and the system recharged with the correct amount. If you aren't sure of the charge then start over and measure the correct amount of Freon into the system. No one here can help you if you don't know.
Old Aug 23, 2021 | 06:50 PM
99f350sd's Avatar
99f350sd
Best to have it evacuated and all the moisture boiled off and recharged to make sure the amount is good....Back in the day I would charge till the return line at the compressor was getting cold... Its easy to over charge. Temps will go down if you do.
Old Aug 23, 2021 | 07:39 PM
jav_eee's Avatar
jav_eee
I did that. 42 ounces (from what I’ve gathered off the internet since my truck is missing the sticker). It blows colder, for a fact, a few ounces less than that.
