Hello, does anyone have the pin out for the traction control button?
There are 5 wires going into the button but from what I can tell only 2 of them are used to pass the signal when pressed.
I swapped the traction control button for the split exhaust brake / traction control button to utilize the brake button as a auxiliary momentary switch. I had to remove pins 1 and 4 to make this work but can’t figure out where those wires lead to or if they are needed for anything.
