Brake Control connections
Old Aug 30, 2007 | 09:23 PM
marvmart01's Avatar
marvmart01
I recently purchased a 95 F150. it has a 6pin trailer connection installed but no brake control. I am trying to install my brake control from a previous vehicle. i purchased an adapter from Ford and plugged the brake control in. I found the 4 wires in the rear connector for turns, ground, etc. But I don't see the wire at the rear for the brake control itself or the power feed for charging while towing. Can anyone tell me where to locate these wires to complete hookup?
Old Aug 30, 2007 | 09:45 PM
grafekie's Avatar
grafekie
Follow the wiring harness backwards to the major wiring cable; it should be there.
Old Aug 30, 2007 | 09:48 PM
marvmart01's Avatar
marvmart01
will it just be a loose wire at this junction?
Old Sep 4, 2007 | 01:01 AM
biz4two's Avatar
biz4two
Arrow
Here is a GREAT resource...
http://www.etrailer.com/faq_wiring.aspx
According to the diagram for a 6-way plug...the center 'A' (black/red wire) is the 12V. The electric brakes 'S' (Blue wire).
If the wires are physically missing from the 6-way plug, then I would highly recommend replacing the plug.
Hope that helps...
biz
