guidance?
Old Aug 20, 2021 | 04:56 PM
judiecutie's Avatar
judiecutie
Trailering
Angry guidance?
Ok, got my '85 back today,,,.the driver door wont close...not sure how to fix the latch inside the door? gets stuck in a locked position?
Old Aug 20, 2021 | 10:44 PM
BigBlue2's Avatar
BigBlue2
Could be a number of issues. How's the hinges? Any play or door sag? How's the condition of the roller and pin on the door post? Is the latch mechanism secure in the door?
Also these doors will stay locked when in the locked position open and then shut. Some older vehicles had to be locked with the key. A handy thing that helps you avoid locking the keys inside. The 80-86 trucks don't have that feature. Yes you can lock your keys in the cab!
Old Aug 21, 2021 | 10:04 AM
Max Capacity's Avatar
Max Capacity
The door card is easy to remove if you have tools. Looks like that will be your next step.
I'm sure you can ask google to find you a door latch.https://www.google.com/search?q=door...hrome&ie=UTF-8
Old Aug 21, 2021 | 03:46 PM
BigBlue2's Avatar
BigBlue2
The sticking may be in the key cylinder. I like to spray Fluid-Film in my key hole regularly. That keeps mine from sticking.
Old Aug 21, 2021 | 04:33 PM
judiecutie's Avatar
judiecutie
Trailering
Ok, figured it out..need to get new roller pins for both doors...perfect fix!! now, what are the best floor mats to get? weather tech has none for my truck...has new carpet...want to keep it clean as I live on dirt road...
Old Aug 21, 2021 | 08:02 PM
FuzzFace2's Avatar
FuzzFace2
Good to hear you found the cause and should be a easy fix.
As for the mats I was lucky that a local member had a used set of Ford mats that matched my used carpet that a 2nd local member gave me.
I would measure the area and then look around in parts stores and on line for something that might work for you.
Dave ----
Old Aug 22, 2021 | 12:24 AM
BigBlue2's Avatar
BigBlue2
Check out these many options. You're bound to find one to your liking
https://www.carid.com/1986-ford-f-25...er=1&sub-model[ourBodyTypeName][]=SuperCab
I looked up for my F250 supercab. So adjust the search as needed
Old Sep 6, 2021 | 07:25 PM
judiecutie's Avatar
judiecutie
Trailering
ok, all is good now..tried the door pin/spindle? from my husbands F250 and the door closes perfectly!! now gotta order some for my truck..
Old Sep 6, 2021 | 07:53 PM
Franklin2's Avatar
Franklin2
You can take a piece of pex 1/2" plastic water pipe, cut it to length, slice it down one side, and slip it over the pin. Works great, lasts a long time and is cheap and easy, no disassembly of the door pin. That's usually all that is wrong, the factory plastic bushing is missing on the pin.
nut1605
Feb 4, 2008 06:26 PM
z 97ford1
Oct 23, 2005 07:55 PM
philman
Mar 20, 2003 09:39 AM
