'96 dash cluster upgrade
Old Nov 1, 2003 | 01:19 PM
gbear62's Avatar
gbear62
I have a '96 Ranger. I am wanting to upgrade the dash cluster. It came with the Speedo, fuel, temp, alt and oil. I am wanting to install a cluster that also has the tach. I have talked to 3 different Ford Service Centers and they are all telling me they do not THINK the '96 was wired both ways. Can anyone give me any help here. Has anyone else done this change.
Thanks
Gary
Old Nov 1, 2003 | 06:34 PM
Dealford's Avatar
Dealford
The standard answer in previous inquiries was that there was only one wiring harness to fit both instrument clusters. Is 96 an oddball year? Try doing a search here for more info.
Old Nov 1, 2003 | 08:52 PM
Ken00's Avatar
Ken00
Welcome to FTE!!!
I don't think they would have used to different wiring harnesses. If you get the cluster and it doesn't work all you will need to do is add one wire.
Old Nov 2, 2003 | 02:44 AM
Hammy211's Avatar
Hammy211
Everything I've seen is that they should be plug and play. My question is what can I do about the odometer. My truck only has 37K and every cluster I've found has more. I've head that tampering with the mileage messes up the whole gauge. Is there any way to get it to the same mileage as my current odometer?
Old Nov 2, 2003 | 03:41 AM
Dealford's Avatar
Dealford
. Has anybody heard of a place to get the clusters repaired?
Old Nov 3, 2003 | 04:35 AM
gbear62's Avatar
gbear62
Thanks for all the replys. I do know you can get the odometer changed. There are shops that are certified to calibrate your speedometer and I believe they can change the reading also. If you want to take the time, you can open the odometer up and change it your self. I know that use to work on older cars. I had a '68 Firebird I did that to. The other option is to get a certified letter stating you changed the odometer.
Gary
xmontex4
Nov 7, 2013 03:20 PM
Apocalypse
Nov 9, 2012 02:48 PM
dragonz118
Escape & Escape Hybrid
Aug 23, 2007 09:26 PM
superdutyquest
Oct 3, 2006 08:53 PM
Johns331
Sep 5, 2002 11:45 AM
