Are the rubber cab mounts and the radiator core support mounts for a 66 cc the same from each vendor or do some vendors have a more correct rubber mount for a better fit?
No longer a fan of DC however when it comes to radiator and cab mounts, weatherstrip, window seals and gaskets I tend to shop with them, Years ago I did purchase a set from another supplier and found the kits inferior.
Items to the left are the front and rear cab mounts. The kit comes w/ 4 extra large washers according to the packaging for 70-72. DC charges $100 for the kit. The items on the right are the radiator mounts, they run around $60. The quality seems very good but I have nothing to compare them to, suggest if comparable set of similar quality may consider going that route???
I think I got mine from Macs, looked just like the ones dave posted. They fit fine. I took the two extra, large washers that came with mine and put them between the cab and frame4 at the rearmost position and it brought the back of the cab just enough to get rid of the swayback look.
