Sponsored by: Real Truck
Def and dpf
Old Aug 18, 2021 | 01:00 AM
Moonman63's Avatar
Moonman63
Def and dpf
I tried tuning my truck with no deletes, now I have a def system fault and I flashed back to stock and I best going to ford and having them fix the issue or just going to get the entire dpf scr and cat delete done and run a updated delete tune please need answers fast I’m about 48 miles away from being in forced idle (def tank is full)
2014 F-250
Old Aug 18, 2021 | 01:08 AM
Just Strokin's Avatar
Just Strokin
Is your truck deleted or not? I could not determine if you are trying to install tune on a non-deleted truck.
Sometimes it takes a few drive cycles to clear a code.
What code did it give you?
Look up here maybe, Ford/Motorcraft OBD info for my2014 6.7
http://www.fordservicecontent.com/fo...DOBDSM1401.pdf
Old Aug 18, 2021 | 01:16 AM
Just Strokin
Towards the end of the video is how to do a drive cycle.
Old Aug 18, 2021 | 02:23 AM
Moonman63's Avatar
Moonman63
I’m not deleted I’m at work so I’m unable to verify what code but I’m flashed back to stock and I’m wondering if this is something that could go away on its own take it the dealer or just do my dpf delete and re tune it
BigBlue99
6.2L V8
Sep 8, 2020 09:08 AM
hd4ever
Apr 5, 2018 01:11 PM
EMD_DRIVER
Sep 17, 2014 03:59 PM
rmort
2004 - 2008 F150
Jan 24, 2011 01:28 PM
suzuki_vinson
13
Sep 17, 2007 06:11 PM
