I could of called them and they would say x and x psi but i wouldnt of learned anything from that. Now i can say this tire is safe at this psi to this psi then work on tire wear.. The safe psi was main concern due to these things weight..
If you know your weights and follow the inflation table to set the pressure required for that weight (with maybe a an extra lb or 2 for elbow room) then that should be a safe pressure for your weight. Big fat tires need less PSI to carry the same weight as a smaller more narrow tire.
