Sponsored by: Kumho
Tire Pressure question
Old Nov 21, 2003 | 08:58 AM
Ripsnort's Avatar
Ripsnort
I have Toyo 235/85-16's. This truck and respective tire types are new to me, the max PSI for a full load is 80 PSI. WOW! Anyway, without a load, what would you recommend for a PSI? I'm currently running 65 PSI in them now.
Old Nov 21, 2003 | 06:04 PM
ctfuzzy's Avatar
ctfuzzy
Re: Tire Pressure question
Brian,
look inside the drivers side doorjam. There should be a sticker there saying what size and load rating tires belong on the truck. ~If~ the tires currently on your truck are that size and load rating, I would recommend that tire pressure.
. . though, off the record, I would probably run 65 in them unloaded too - it'll ride MUCH better.
HTH.
