Bronco II Ford Bronco II
Engine won't start
Old Nov 10, 2003 | 10:14 AM
nightcrawlermc's Avatar
nightcrawlermc
I tested the wires and I found four bad wires. 3 coming from the TFI module and 1 coming from the resistor that burnt up. I looked at the wiring diagram and it looks like they all go to the Electronic Control Assembly. I know even less about wiring than I do about the rest of it, but from what I can tell that resistor that came loose caused a short circuit. Could it have just blown a fuse, and if so where is that fuse at? Or do I need to replace those 4 wires, and if so where is the electronic control assembly? I appreciate any help.
Old Nov 10, 2003 | 03:47 PM
nightcrawlermc
I found the ECA and I found a fusible link, but I'm not sure what it works with. It's with a group of about 5 wires that comes off the large group of wires that hooks to the ECA. I read about the ECA in the Haynes Manual and I'm wondering if I might just need to replace the whole thing. Is there a way to find out if it needs replaced? A new one is $96 so I'd like to test the old one if possible.
Old Nov 11, 2003 | 09:22 PM
Gutter's Avatar
Gutter
the modual on the back of the distributor is your best bet
Old Nov 13, 2003 | 06:21 PM
stepman's Avatar
stepman
What do you mean by you found 4 bad wires? Get a skematic and you'll see how the wiring runs between the module and the PCM.. Get a meter and check these for continuity. Also check your fuses. Check them all. I'm not sure which ones are for the PCM but, there should be 1, maybe 2 (10amp). If that checks out, you may have a fried comp. I don't know of anybody that can test them. They are more of a "test everything else" and process of elimination educated guess type thing.
ivegotahammer
28
Oct 4, 2022 02:08 AM
Michael Cieslik
18
Dec 3, 2016 08:07 PM
Murfy101
3.8 & 4.2L V6
Oct 1, 2015 06:23 PM
exidor12
Sep 13, 2015 06:34 AM
Hershman3
Jul 3, 2008 08:52 PM
