Sponsored by: Real Truck
Clutch issues HELP
Old Aug 13, 2021 | 11:08 AM
eventer1993's Avatar
eventer1993
Clutch issues HELP
I took my 2001 Ford F-250 to a transmission shop to have the clutch replaced. 7.3 with six Speed manual. 225k miles. They said when they took it apart, the pilot bearing was in pieces. I needed a new master and slave cylinder as well. They installed a pre filled master/slave. Installed a new clutch. Machined the flywheel. I went and picked it up. After it got hot, it started grinding very randomly. It’s the most random thing. I press the clutch in, shift into a gear, let the clutch out, and you can hear a short lived, quick grind as if you shifted wrong. The clutch pedal feels fine. Shifts into gear perfectly smooth. You never know what gear it’s going to happen in and you never know when it’ll do it. Sometimes when you put it in neutral, you can hear a grind, thud, or clink. The boot on the shifter is ripped, so it’s all very loud. I took it back to the shop, and they had to drive it a few times to even recreate the sound. When they heard it, they said it’s internal of the transmission. I’m not buying it. They didn’t even inspect the clutch again. There were none of these noises before they replaced the clutch. None. Never any of these issues. They said it would be $3k to rebuild the tranny and $5200 to put a rebuilt one in it. I really think they did something wrong when they replaced the clutch. Has anyone ever had this happen?? I want a second opinion from another set of eyes. I’m picking the truck up today. But I would like an idea of what this could be.
Stymied
21
Jun 13, 2016 09:23 PM
thordehr
25
May 19, 2016 09:17 AM
1990fordf-250
Dec 21, 2014 05:41 PM
charlessocccer
34
Dec 15, 2010 03:17 PM
d3ryl
Apr 26, 2009 08:08 PM
