95 460 lean under load
Old Aug 12, 2021 | 09:00 PM
Wd6681's Avatar
Wd6681
I am the new owner of a 95 f250 5 speed with a 460. I have been tuning the truck up with fresh coolant, cap rotor, plug wires, plugs etc.
I Have only driven the truck about 70 miles but the big hills near me have exposed how the truck runs lean climbing hills, enough to make the truck buck slightly especially under partial throttle. Scanning it I did get a lean code and all the plugs were slightly white when changing.
for for what I have triedFuel filterRepairing butchered wiring to tank selector switchFuel pressure regulatorThe fuel pressure at the rail is right at the bottom of the spec (with both old and new regulator), 30psi at idle and 35-38 with vacuum disconnected. I figured it couldent be the pumps as it runs like this from both tanks. However I did finally test the rail pressure on the rear tank and it was maybe 1-2 psi below the rear tank pressure.
could both pumps be low on power simultaneously? Please talk me off a ledge here!
Thanks
Old Aug 12, 2021 | 09:40 PM
Conanski's Avatar
Conanski
Fuel pressure would have been my first guess but those pressures look acceptable, you should probably still figure out some way to monitor it while driving to see if the pumps have a volume problem.
Any evidence fuel is being transferred to the inactive tank?
Yoiu could also try disabling EGR, just disconnect and cap the vacuum line at the valve and take it for a drive.
Old Aug 12, 2021 | 10:32 PM
wwhite's Avatar
wwhite
What kind of fuel are you running?
Tried a tank full of something different?
Old Aug 13, 2021 | 10:59 AM
Wd6681's Avatar
Wd6681
Pulled the EGR vacuum and capped it. Maybe it runs better. Interestingly it is possible that the rear tank is returning to the front as the full tank became near empty from very little driving and lots of idling. I filled both tanks today and the front was reading empty and only took 6 gallons, filled it still reads empty. Truck definitely runs poorer on the front tank, (a little hesitation, rougher running).
Old Aug 13, 2021 | 05:17 PM
Conanski's Avatar
Conanski
Good chance you have the fuel transfer problem, that bleeds of some volume that should go to the motor... potentially enough that the motor would be down on power.
The fuel level sender in your front tank is dead, the pump is weak, and the check valves that should prevent crossflow aren't working either so you may as well drop that tank and replace the whole FDM.
Old Aug 14, 2021 | 02:59 PM
Wd6681's Avatar
Wd6681
I Have a new fdm coming for the front tank. This kind of makes sense because when I checked fuel pressure with the front tank it bled like there was more pressure than before but kind of foamy. I think the bad front tank fdm is getting air in the line. Thanks for th guidance, will report back with results
Old Aug 26, 2021 | 05:30 PM
Wd6681's Avatar
Wd6681
New fdm in the front tank, truck is 90% there. Runs equally as well on the front and rear tank now but there is still an intermittent miss at partial throttle which clears up when you give it more throttle.
Old Aug 27, 2021 | 02:49 PM
Conanski's Avatar
Conanski
Have you pulled the codes lately? The TPS could have a flat spot that is generating that partial throttle problem, somtimes this sets a code sometimes not, worth a look either way.
wevie
Aug 26, 2021 07:02 PM
Manaze450
Jul 12, 2016 08:52 PM
harrisdigi
Oct 30, 2014 01:12 PM
digicon
Feb 22, 2014 03:30 PM
