95 f250 runs crappy on from tank
Hi all, I've read some posts on this subject but I thought I would ask directly. So my 95 f250 5.8 86kmiles runs great on the back tank plenty of power, but on the front tank it runs, but it doesn't run good. If you're just cruising it'll get you around but if you mash it , it will rev up but not really pull. On the back tank it pulls great. Feels like its starving for fuel, seems obvious that it needs a front tank pump. I'm not having any problems with fuel crossover or anything like that , just a lack of power when it's asked for on the front tank. Thoughts?
Put a fuel pressure gauge on the test port. Look at the pressure readings under the same conditions for each tank. At idle the pressure should be ~30-35 PSI. Under load the pressure should go to 40 PSI and stay there until you let off the throttle/vacuum increases.
Since you do not have the crossflow problem it's probably just a weak pump.
You can rent a fuel pressure gauge at most auto part stores. It's your wallet and your choice of path to take. Other possibility is a plugged up filter sock on the front tank. You have to drop the tank to service/inspect. Knowing the fuel pressure up front would be beneficial to know IMHO.
Primered86XLT
03-23-2005 05:21 PM
