Turn Signal Issue
Old Aug 12, 2021 | 05:07 PM
TXBuilder's Avatar
TXBuilder
Turn Signal Issue
I have a 1976 F150 4wd . The front left turn signal will not work, all the others do. When I turn on the lights, all the turn signals stop working. I have checked/replaced all bulbs, cleaned all bulb sockets, and inspected wiring. I can find no issue with the wiring. Any ideas?
Thanks
Old Aug 12, 2021 | 09:48 PM
Idaho Highboy's Avatar
Idaho Highboy
Veteran: Navy
TX, do you have a test lamp that you can pierce the wire ahead of the front left socket to see if a signal is making it that far? Can you be more specific re: any troubleshooting you've done?
- IH
Old Aug 12, 2021 | 10:46 PM
John89's Avatar
John89
Check and clean all grounds, even the ones not specifically associated with the lights.
Battery to block
block to frame
engine to firewall
etc...
Then check all sockets with test light/ meter as mentioned.
I think everyone on here has chased lighting gremlins at least once.
Old Aug 13, 2021 | 06:52 AM
TXBuilder's Avatar
TXBuilder
- IH
I have not used a test lamp. I have inspected and cleaned all light sockets, checked and replaced all bulbs and inspected the wiring for ant visible damage. Last night i replaced the flasher module and the blinkers all started flashing when the right one was turned on, none when the left was turned on. I reinstalled the old flasher module and now the same thing, when you turn on the right side they all come on, engage the left and nothing works. I will say the left front appears to be much dimmer when they all come on.
Old Aug 13, 2021 | 04:33 PM
Idaho Highboy
Veteran: Navy
Could be a couple of things if one side isn't working and we shouldn't assume that whatever is affecting the forward signal is affecting the rear. Can you use your multimeter lead to poke through the wiring ahead of your front and rear left sockets to see if you get 12vDC when you activate the turn signal?
- IH
Old Aug 14, 2021 | 10:30 AM
5851a's Avatar
5851a
99% of the time it will be bad ground. The Ford turn signal sockets have 2 piece construction on the ground contact wire. It can and will corrode at the hidden joint, you can have a good ground wire going in but no ground on the bulb side. The replacement sockets don't match the factory colors so you have to check them out.
HVACTOM
Feb 14, 2015 04:33 PM
Ole 64
May 8, 2012 04:49 PM
royboytrip
19
Dec 8, 2009 04:19 PM
Cardiac69
Nov 1, 2008 05:41 PM
greenterror
Electrical Systems/Wiring
Apr 9, 2004 06:58 AM
