turn signal problem??
Old Dec 3, 2009 | 10:04 PM
royboytrip's Avatar
royboytrip
have a 78 ford trk.got all the lights to work,but when you turn on the headlight, the passenger side turn signal quits blinkin,turn off the headlights,and it works,anyone out there,got a clue on whats happening,got me stumped,course not a wiring man,any help would be great,,,,thanks for a cool site.
Old Dec 3, 2009 | 10:43 PM
CaptainIPSC's Avatar
CaptainIPSC
Check your ground wires from your head light buckets to the core support.
Old Dec 3, 2009 | 11:14 PM
royboytrip's Avatar
royboytrip
turn signals
thank you, i will.other friend early today said same thing,just too cold out until tomorrow,thought i would check with u guys,I like this site alot,like scrolling thru the questions ,learn alot,later on.
Old Dec 4, 2009 | 09:42 AM
M. P. Gray's Avatar
M. P. Gray
Turn signal weirdness
Speaking of turn signals, here's a head-scratcher: My turn signals work fine. The front and rear lights work when the signal is turned on. But when the headlights are also on the driver's side signal (green arrow light in dash) stays on unblinking. I will blink when the signal is on but when the signal is turned off it remains on and unblinking. Any suggestions? This is in a 1976 f250. Thanks!
Old Dec 4, 2009 | 11:52 AM
montana_highboy's Avatar
montana_highboy
Grounding issue, also make sure the ground wire is firmly pressed into the the back of the bulbs socket.
Old Dec 4, 2009 | 11:59 AM
M. P. Gray's Avatar
M. P. Gray
Is that the dash bulb or the headlight you're referring to? Thanks.
Old Dec 4, 2009 | 12:04 PM
montana_highboy
The turn signal bulb itself, not the dash light.
Old Dec 5, 2009 | 04:45 PM
Mike's 77's Avatar
Mike's 77
If the ground wires are not the issue it could be the problem I had in mine which was the turn signal switch went out which caused my signals to not function properly or even not at all, and also the brake lights would not work or stay lit at times.
Old Dec 5, 2009 | 05:11 PM
highboy1975's Avatar
highboy1975
replacing the switch on mine was a very good idea, i needed to do it, but i put an aftermarket wheel on, the signals and flashers work perfectly, and i know what i have.
Old Dec 5, 2009 | 05:15 PM
Mike's 77's Avatar
Mike's 77
only problem I had with mine was finding a switch w/ cruise control since that part hadn't been made in many many years but I found one and no longer have any problems with lighting and th CC works again. For a switch w/o CC they're easier to find and a bit cheaper as well. Not too difficult to replace either.
Old Dec 5, 2009 | 07:26 PM
ArcadeTom's Avatar
ArcadeTom
Hey everyone! It's been sort of a long while since I posted, but Old Blue is going to finally come home from the paint shop on Monday and I have to finish up some small issues. (wiring)
I took Old Blue all the way down to the frame and back up. Everything seems to be working fine, but I have something puzzling me: When I turn on the turn signal the side marker blinks as well if the headlights are on.
It's been so long since I had it running (three years) I have forgotten if they are supposed to blink.
Can someone tell me if the side markers (front) blink with the turn signals and with the headlights on?
Old Dec 5, 2009 | 09:48 PM
460Brnc's Avatar
460Brnc
No. the side marker lights are not suppose to blink with the turn signals.
Old Dec 6, 2009 | 08:54 AM
ArcadeTom's Avatar
ArcadeTom
The really strange part is that everything blinks like it is supposed to, but I just don't remember the side markers on the front doing that. Go figure.
By the way, I have a link to the work on my '74. I should have some new pics posted this coming week with the final paint and stripes.
http://www.cardomain.com/ride/2537897
Old Dec 6, 2009 | 12:06 PM
Mike's 77's Avatar
Mike's 77
The side marker lights? Just out of curiousity, are they LED? I swapped the front corner lights (in the side trim on the front) to matching 194 style LED's and for some reason when I have the headlights on the driver side light will blink or flash, either really fast, slow or not at all. It could be reverse polarity, but I haven't gotten a chance to fix that yet since the truck is in the shop getting a new motor right now.
Old Dec 6, 2009 | 01:58 PM
ArcadeTom's Avatar
ArcadeTom
Yeah, side marker / corner lights..In the side trim in the dent side. I'm using all brand new bulbs and even new front turn signal units.
