Sponsored by: Real Truck
Engine problem
Old Aug 12, 2021 | 04:36 PM
klausd's Avatar
klausd
Engine problem
I have a 1999 f250 superduty v10 triton and when I am in drive at idle it acts like it is starving for gas and wants to die. it doesnt do it all the time just random. Any ideas?????
Old Aug 12, 2021 | 04:48 PM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
Sounds like the automatic idle control sticking.
Denny
Old Aug 12, 2021 | 04:57 PM
klausd's Avatar
klausd
Any idea where thats at?
Old Aug 12, 2021 | 08:57 PM
rvpuller's Avatar
rvpuller
Top of the throttle body near the back.
Old Aug 14, 2021 | 01:03 AM
reptar0077's Avatar
reptar0077
Have you ever changed out your fuel filter? After that I would remove your air intake and clean your throttle body out, as both of these are cheap and can
yield amazing results if never done. After that then yes I would check your idle control valve.
Old Aug 14, 2021 | 07:16 AM
klausd's Avatar
klausd
No but I will now, I was just going to run some fuel system cleaner and hope from there
Old Aug 21, 2021 | 03:16 PM
klausd's Avatar
klausd
Do you think that it would be my fuel filter if it only does it while i am in a idle position and not driving?
Old Aug 26, 2021 | 03:12 PM
farmerfromkansas's Avatar
farmerfromkansas
Changing the fuel filter is not a bad idea, I was having trouble with my f-450, and replaced the fuel filter, but the old one was clean. Wound up replacing the fuel pump. Huge difference for mine. But my issue was the truck would sometimes not start. And had to crank it a lot when it did start. Now, it starts quicker with less cranking, and has better power at low speed, and starts every time.
iamme81702
Oct 21, 2010 08:46 AM
atmotion
Jan 2, 2010 02:27 PM
Lightfoot15
Dec 6, 2004 08:58 PM
yz429
Modular V10 (6.8l)
Jan 6, 2002 11:50 PM
