Need help with p1335 code
Old Aug 10, 2021 | 10:19 PM
Josgon328's Avatar
Josgon328
I just got my 2004 F250 super duty 6.0 diesel bulletproofed with a bulletproof turbo, egr cooler, oil cooler and ARP studs and it is still giving me the p1335 code. My egr is under warranty so I got a new one and reset the light but I came back on. I also replaced the y pipe because it had a leak. Anyone know what it could be? I examined the harness/connector and it has no damage.
Old Aug 11, 2021 | 06:31 AM
bismic's Avatar
bismic
How long have you driven it after replacing the valve?
What did the intake manifold look like when the valve was out?
Were you having problems (and what were they) before you replaced the valve?
Are you tuned?
Old Aug 11, 2021 | 07:07 PM
m-chan68's Avatar
m-chan68
Do you have access to a scan tool that can read live data? If so, have a look at the EGR_VP volts PID at key-on/engine-off. You should be seeing a reading of about 0.85 to 0.95 volts if I recall correctly. If you're seeing voltage above 1.0 volt, either your EGR valve is stuck partially open or the EGR valve position sensor is faulty and needs replaced. It would be far from the first bad-out-of-box EGR valve.
Old Aug 11, 2021 | 08:29 PM
Josgon328's Avatar
Josgon328
Are you tuned?
I'm not tuned and the intake manifold was cleaned by the mechanic. I got it bulletproofed after the egr cooler was bad and starting using up coolant and was giving steam from exhaust. I also noticed that the egr was dirty when I changed it out.
Old Aug 12, 2021 | 10:49 PM
Josgon328's Avatar
Josgon328
The truck now has a p0404 code as well
Stevem4134
6.7L Power Stroke Diesel
May 10, 2019 08:33 AM
diesel stopper
Mar 16, 2016 01:33 PM
EMC V10 X
Nov 19, 2014 05:19 PM
dvrjump
Apr 12, 2014 12:57 PM
salty
May 16, 2009 06:24 AM
