High pressure A/C switch to protect compressor
Old Aug 10, 2021 | 03:07 PM
sailorman524's Avatar
sailorman524
Trailering
There's go to be a logical explanation why the earlier units don't have a high pressure switch to protect the a/c compressor. Should be easy to add on the discharge side and in series with the low pressure switch. I blew the compressor seal due to overly clogged condenser. Anybody done this ?
Old Aug 10, 2021 | 07:51 PM
genscripter's Avatar
genscripter
I looked into this years ago when my system couldn't really keep up after the 134a conversion. My rear evaporator works great, but the front is lukewarm. I can't increase the pressure precisely due to what you're describing. Maybe with a high side switch, it would let me push the limit a little more, but never worked it out. I did find a company that made high-side switches that fitted to the 134a conversion valves if you wanted to go that route, but I think it was kinda pricey.
Old Aug 10, 2021 | 11:44 PM
sailorman524
Trailering
Here's the easier part
1. 4 Seasons 36646 system mounted binary pressure switch
2. 4 Seasons wire harness connector 37219
Now, just need a tee on the discharge side between compress and evaporator...
Old Aug 20, 2021 | 05:13 PM
tecgod13's Avatar
tecgod13
I upgraded my truck last year. Used parts from maybe a 94? New compressor, condensor, and lines etc... The new line from compressor to condensor had the T for the high pressure switch built in, so I just had to snip the wires and add in the pigtail and switch.
I ran into a small snag since I didn't reuse the evaporator and the line size was different at that connector, but was able to cut the old one and put in a flare connector that has been holding fine.
Sauce06
Apr 3, 2016 08:38 PM
MJ04350
Jun 15, 2014 06:38 PM
colonelsanders2k7
May 30, 2011 04:12 PM
jvr-sfbay
May 22, 2004 09:41 AM
73highboy4x4
13
Apr 19, 2004 09:02 PM
