explorer a/c pressure switch
Old May 30, 2011 | 03:57 PM
colonelsanders2k7's Avatar
colonelsanders2k7
I have a bad a/c pressure switch and was wondering if anyone knows whether or not I have to evacuate the r-134a before replacing? It is the switch on the backside of the compressor. Thanks in advance.
Old May 30, 2011 | 04:12 PM
scucci's Avatar
scucci
From the service manual:
The A/C pressure cut-off switch is used to interrupt A/C compressor operation in the event of high system discharge pressures.
The A/C pressure cut-off switch is mounted on a Schrader valve-type fitting on the high pressure side of the A/C manifold and tube.
A valve depressor, located inside the threaded end of the A/C pressure cut-off switch, presses on the Schrader valve stem.
This allows the A/C pressure cut-off switch to monitor the compressor discharge pressure.
When the compressor discharge pressure rises to approximately 2896 kPa (420 psi), the switch contacts open, disengaging the A/C compressor,
When the pressure drops to approximately 1724 kPa (250 psi), the contacts close to allow operation of the A/C compressor.
It is not necessary to discharge the refrigerant system to remove the A/C pressure cut-off switch.
Brooks Rowell
May 31, 2025 09:02 PM
bismic
Mar 19, 2017 05:14 PM
shapechanger101
Sep 25, 2016 07:32 PM
jstihl
17
Jan 18, 2016 09:25 AM
vent
1983 - 2012 Ranger & B-Series
Jun 4, 2010 12:51 PM
