2016 Shocks on 2020?
Old Aug 9, 2021 | 02:25 PM
IggyD's Avatar
IggyD
I have a friend of mine is selling his shocks from his 2016 F250. He's only had them for 2 months and is selling because he's going with a lift. The price is too good to pass up, but this may seem like a dumb question, will they fit my 2020? Most places say no, but I wanted to double check.
https://www.ridefox.com/product.php?...position=Front
Old Aug 9, 2021 | 02:44 PM
4wd6.7L's Avatar
4wd6.7L
The fronts might be the same, but the rears might have a different diameter bushing i.d. on one end.
Old Aug 10, 2021 | 10:33 AM
HRTKD's Avatar
HRTKD
This was certainly true for the 2017 model year. I can't speak to later years, but I haven't heard that there was a change other than they lowered the rear a bit for 2020+.
Old Aug 10, 2021 | 01:51 PM
IggyD's Avatar
IggyD
I’m thinking the same thing. The 17-19’s would work, but not sure on the 16’s. In terms of part numbers is looks like there is a clear split between shocks in pre 16 and post 17. It looks like they fit, but I’m not sure if the lengths are different and would cause problems. It’s a bummer shocks are so hard to come by these days.
Old Aug 10, 2021 | 02:22 PM
ford390gashog's Avatar
ford390gashog
The 16 shocks will work just fine on 20+ that are stock height and not Tremor equipped. The 17-19 sit higher and the shocks will not work.
Old Aug 10, 2021 | 02:33 PM
4wd6.7L's Avatar
4wd6.7L
What about bushing size? I'm finding that its 16mm upper, 14mm lower on the rear for 17-21, and 16mm upper, 12mm lower for the rear on 99-16. Still haven't found a definite lower size for the fronts to compare.
I do see an overall travel difference when looking at shocks for 16 and older compared to shocks sold for 17-21. The pre 17's did sit lower.
nagetech
Jul 25, 2011 07:33 AM
homesteader
18
Apr 13, 2010 01:25 PM
chewy8000
May 21, 2007 11:04 AM
khmorse
Mar 6, 2004 10:12 AM
Mush's 88
Feb 12, 2004 10:16 AM
