2021+ F150 Discuss the 2021 Ford F150
Sponsored by: Real Truck
Noisy fuel pump?
Old Aug 9, 2021 | 03:39 AM
Bill Nolan's Avatar
Bill Nolan
Noisy fuel pump?
2021 F-150 Supercab 5.0L 36 gal gas tank. When I open the door first thing in the morning I have a very noticeable (what sounds like a fuel pump) noise coming from the direction of the fuel tank. Is this normal? I never heard it with my 2011 F-150 regular cab 5.0L 36 gal fuel tank equipped truck.
Old Aug 9, 2021 | 10:14 AM
seventyseven250's Avatar
seventyseven250
Yes that's the fuel pump and yes that's normal and no cause for concern. Happens when the drivers door is opened. It' is surprisingly loud.
Old Aug 9, 2021 | 03:17 PM
Bill Nolan's Avatar
Bill Nolan
Accepted. But wondering why my 2011 did not make that noise… essentially the same setup…
Old Aug 9, 2021 | 03:31 PM
seventyseven250
I don't know why Ford went to a different fuel pump strategy. Would be interesting to know. Probably happened around 2018 when the engine got a bunch of updates, although that's just a guess on my part.
Old Aug 9, 2021 | 04:56 PM
ford390gashog's Avatar
ford390gashog
The two trucks have nothing in common, the entire drivetrain and fuel system is different. The engines are not even related and the 2021 has 16 fuel injectors and two split fuel systems.The noise is normal an is found on most vehicles that have direct injection.
Old Aug 11, 2021 | 12:10 PM
MisterCMK's Avatar
MisterCMK
The 11 will prime the fuel pump as soon as the key is in the ignition switch. The 21 primes it when the door is opened.
Old Aug 15, 2021 | 02:55 PM
brandonrr's Avatar
brandonrr
I just assume Ford did this for the people that swiftly insert the key and start it in one motion. I notice the sound very clearly on my 2019 3.5 when I open the driver's door.
Old Dec 5, 2021 | 05:28 PM
RedDawg4's Avatar
RedDawg4
Trailering
I wonder if....
That was the first thing I noticed. Could it possibly be because they've deleted the gas cap? Could let more pump noise out through the filler tube.
fordguy7904
Feb 24, 2024 01:53 PM
Mikeyc187
6.7L Power Stroke Diesel
17
Mar 2, 2013 10:43 AM
caedo
Jan 26, 2013 01:59 PM
mtntop1
Jun 15, 2009 06:52 PM
fordtruck88
Oct 31, 2007 03:08 PM
