Plug Wire Durability?
Old Aug 8, 2021 | 09:15 PM
kr98664's Avatar
kr98664
Anybody have a favorite brand of spark plug wires to recommend? I've had several sets fail and am about to tear my hair out, at least what's left of it. Actually, I still have all my hair, but unfortunately most of it is in the shower drain and of little practical use to me, but already I've digressed.
The failures are all the same. The conductor breaks next to the crimp at the plug end. I ALWAYS use plug wire pliers to remove them, so am not just yanking on the wires. And I rarely have to remove them, so it's not like I'm wearing them from removal and installation.
Heat from the exhaust may be a factor, but I've got stock manifolds, not headers. The manifolds are aftermarket replacements and are slightly beefier than stock, so the original sheet metal heat shields won't fit. I tried some braided silicone sleeves with one set, but it made no difference.
The brands that have failed are AC Delco, Motorcraft, and NAPA Premium. All had 45 degree silicone boots at the plug ends. Engine is an '84 351W with Duraspark II. Thanks for any recommendations.
Old Aug 8, 2021 | 10:39 PM
ctubutis's Avatar
ctubutis
I've had Belden 8mm on my truck for lots of years without problems.
If I were you, I'd next try AC Delco, or maybe something from Summit Racing or Jegs. Maybe NGK or some such.
Old Aug 9, 2021 | 08:28 AM
Max Capacity's Avatar
Max Capacity
Have to agree with Belden 8mm put these on back in the late 1990's.
Old Aug 9, 2021 | 09:54 AM
Olds64's Avatar
Olds64
You can get stock spark plug wires from the auto parts store with a lifetime warranty. That way, if they fail you can swap them for a new set.
I've had good luck with the "fabricate your own" kits available at Summit and Jegs. Just make sure you get a set of ratcheting crimpers with the proper jaws to crimp the ends.
https://www.summitracing.com/search/...asummit-racing
Never found a use for them on my truck though...
Old Aug 9, 2021 | 10:00 AM
Max Capacity
Just did a quick search, did NGK buy Belden ?
Found some Belden on ebay sites...
Old Aug 9, 2021 | 01:50 PM
kr98664's Avatar
kr98664
Hmmm. I should clarify the set I called "NAPA Premium" was actually Belden. Apparently it's a house brand with NAPA:
https://www.napabelden.com/index.html
This is the most recent failure, installed about one year ago. I wonder if Belden has recently cheapened their manufacturing process, as they seem to be highly recommended.
Old Aug 9, 2021 | 02:18 PM
FuzzFace2's Avatar
FuzzFace2
What are you doing, pulling the wires off 3 time a day?
How do you know they go bad or you removed them (again why?) and it broke when pulling the wire off?
My wires & plugs were installed 5+ years ago and have not needed to pull a wire off a plug so what gives with you?
Dave ----
Old Aug 9, 2021 | 02:22 PM
Max Capacity
Oh dear, hope this doesn't go sideways...
Old Aug 9, 2021 | 02:42 PM
FuzzFace2's Avatar
FuzzFace2
Carl can take it
I just cant see how they can break when they are on the plug.
How did he find it and them only being a year old?
I know sometimes the boot can be a bear to get off the plug but I twist the boot and they come off.
Dave ----
Old Aug 9, 2021 | 03:10 PM
kr98664's Avatar
kr98664
How do you know they go bad or you removed them (again why?)...
In all cases, I've had minor rough running that was cured with new plug wires. The problem would reoccur about a year or so later. When I pulled the plug wires for inspection, I'd find one or two broken at the plug end. Did I break them? Who knows, but I removed them gently with special pliers that grip the boots. I NEVER touched them between installation and replacement.
This last time, I had a light misfire present on a year-old Belden set. I did a cylinder balance test by pulling the distributor ends one at a time. I had not touched the plug wires at all since installation last summer. Two adjacent cylinders had no effect when disconnected. This concerned me, thinking it might be a bad head gasket. When I pulled the plug end of the wires, once again the terminals were found broken. As always, I'd used plug wire pliers to grip the boot.
I'm at my wits' end, as these seem to be quality sets. I've tried several different brands. I've consistently had some kind of misfire appear BEFORE I've pulled the wires, so I don't see how I'm killing them. In all cases, new plug wires cured the misfiring, at least for a year or so.
Old Aug 9, 2021 | 03:40 PM
Onions.n.Butter's Avatar
Onions.n.Butter
Working at an automotive shop, NGK is absolutely the way to go. MSD seem to be good as well, but not readily available. We always go for Belden if NGK isn't in stock, but their ends like to come off, even when new. I love the Ford Racing ones on my '86, not sure if they make those anymore.
Old Aug 9, 2021 | 04:49 PM
Max Capacity
Dose Accel still make plug wires... I had them back in the mid 1970's HAHA
I would hope MSD still sells quality stuff.
Old Aug 9, 2021 | 05:56 PM
FuzzFace2's Avatar
FuzzFace2
I have heard of the plug end of the wire slipping off the plug because of the silicone grease they put on the wires but I have not had any break like that.
You said they were 45* plug ends what if you went with 90* ends or if they will fit straight ends.
I have never used a set of wires with 45* ends so wonder if that is why they are failing?
Dave ----
Old Aug 9, 2021 | 06:48 PM
moose4x4's Avatar
moose4x4
FTE Emeritus
I have started using these,
https://www.oreillyauto.com/detail/c...?q=10083&pos=0
They are straight boots though. They have ceramic ends.
Also make sure you have the wires routed correctly. 2 of them on a 5.8 will crossfire. can't remember which ones.
Old Aug 9, 2021 | 10:42 PM
kr98664's Avatar
kr98664
All of the wire sets have had 45 degree ends. This arrangement fit very nicely. I think 90 degree ends would be too close to the exhaust manifolds.
I could possibly use straight ends but #8 is pointing towards the firewall and would require a sharp bend. #1 might also require a sharp bend to clear the heat riser tube, but I’m not sure.
