Eot ect delta
Old Aug 7, 2021 | 10:24 AM
2005x6.0's Avatar
2005x6.0
Eot ect delta
Just downloaded the torque pro app and cruising at 68 unloaded for 1hr my ect temp was 190.4 and my eot was 202 .never went any higher...is my oil cooler on it way out.or is that acceptable
Old Aug 7, 2021 | 10:31 AM
2005x6.0's Avatar
2005x6.0
And driving 45mph it went down to 198 went back up to the 202 when I hit around 70 mph
Old Aug 7, 2021 | 10:36 AM
Brotherbillstruck's Avatar
Brotherbillstruck
That is within the 15 degree limit. Barely. Flat ground on the test? I think 68mph is high for the test, but I do not remember exactly what the test parameters are. For me, I would be thinking about a flush/backflush of the cooling system to try and buy some time before needing an oil cooler. I didn't see anything about backflusing in the Tech folder at the top of the forum but there is a coolant flush procedure. I did find a thread that might help you decide.
https://www.ford-trucks.com/forums/1...bad-temps.html
Old Aug 7, 2021 | 10:40 AM
2005x6.0's Avatar
2005x6.0
Not flat ground a couple hills here and there on the flat section watching it .it barely broke over 200 degrees for a 5 mile stretch .
bismic's Avatar
bismic
So, what coolant are you using?
Old Aug 7, 2021 | 10:44 AM
Brotherbillstruck
Doesn't sound bad. I would still get acquainted with the cooling system fixes while you have the time and you are not in a bind.
Old Aug 7, 2021 | 10:48 AM
2005x6.0's Avatar
2005x6.0
I'm running the ford cold coolant .
Old Aug 7, 2021 | 10:50 AM
2005x6.0's Avatar
2005x6.0
Gold coolant .had it flushed the beginning of the year not knowing how bad the stuff is .I know I have to get that stuff out of there when the time permits
Old Aug 7, 2021 | 11:34 AM
bismic's Avatar
bismic
It is best to get it flushed and changed when the oil cooler (and coolant system) is relatively clean.
Old Aug 7, 2021 | 07:43 PM
Bitterroot Diesel's Avatar
Bitterroot Diesel
Former Vendor
Flush with restore and restore+, install filter and ELC.
05 f250 6 inch lift
Jul 18, 2019 10:32 PM
Macrosill
Jul 17, 2019 01:02 PM
jl4407
Jul 5, 2012 12:23 AM
fatcowvtx
Dec 6, 2010 05:44 AM
