1986 EFI Timing
Old Aug 5, 2021 | 08:54 AM
diggerrigger's Avatar
diggerrigger
1986 EFI Timing
My 1986 5.0L EFI truck has always had the base ignition timing set at 10° BTDC as directed. I find it curious that with base timing set at 10° BTDC, when SPOUT is connected the ECM likes timing at idle to be in the neighborhood of 20° BTDC. Seems to move around just a bit too +/- 2° as the idle speed varies slightly around 700 rpm.
I have always thought that the timing at idle should be closer to the base setting. Or, is this just the way it is?
Old Aug 5, 2021 | 12:35 PM
Glaser67's Avatar
Glaser67
Just they way it is, no worry, otherwise, why have the spout at all right?
Building_Fords
Oct 12, 2016 10:44 PM
Jason302
Jun 9, 2011 07:52 PM
Rintin69
Jan 18, 2006 01:00 AM
Dannym
Aug 13, 2004 02:29 PM
northlandman
Dec 1, 2003 06:49 AM
